Wifi Adapter + External Antenna
AlexAdam
it looks like the standard connector , idk if it will help with range, i bought one of those cantenna things and it really didnt help too much.
why arent you going for the 300mbps version with two antennas and higher dl speed?
if i post a link to amazon try to use the LTT affiliate code to help the channel http://www.amazon.com/?_encoding=UTF8&camp=1789&creative=390957&linkCode=ur2&tag=linustechtips-20
I want more signal on wifi (i take from my neighbord) and i dont have enough signal...at night i have no problem.
i dont need more dl speed im ok with 800kb/s ;)
ah ok, lol. yea thats the standard connector, i have mixed and matched antenna on routers and wifi cards so it should work .
http://wireless.gumph.org/content/3/7/011-cable-connectors.html
