cpu fan is going to fly
lolsmurfzs
so i was plaing this heavy game called: SNOW, when the cpu fan reached ~65 degrees. cpu fan started going around 4800 rpm and the noise it made wasn't good.
i have i feeling it is going to fly out of my case, because if i set it to manual mode 100% (almost 5000 rpm) the noise it makes sounds like a helicopter going into a wall.
what do i do?!
EDIT: if it's hot and i set it to 100% it's around 500 rpm, if cpu is not hot and i set it on 100% it's around 3500 rpm.
Can I see the fan curve?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
you mean this?
If you have tried cleaning the fan/heatsink, maybe try tweaking the curve so that it keeps the temps a bit higher, 65 degrees is not so terribly hot 5 degrees more should be okay and may keep the noise down. Also, you can use Alt+PrintScreen to capture one window instead of the whole desktop.
haven't done that, i'll give it a try
i did not know that! thank you!
11 minutes ago, lolsmurfzs said:
you mean this?
yes, can you show a image of that window only
Make it only go at 4500 at 75 degrees.
