So I just got a new hard drive and went to put it in how ever I need to move some stuff around I thought that it would be find how ever once everything was in place my PC would not get power so I put if all back to where it was and still nothing would love some help
https://linustechtips.com/topic/575420-pc-stoped-working-would-like-help/
What??? Could you rephrase your question?
-edit- 1000TH POST!!!! WOOOOOO!!!
ASU
I recommend checking your PSU to assure you didn't accidentally turn the on switch to off first. If you are trying to do a basic file transfer from one HDD to another, I would also recommend just using a flash-drive and selecting the files you want moved over. The question you're asking isn't quite clear, sorry I couldn't be much help. Good luck!
