I have to write a program that takes a list of names from the user and then puts them in title case and sorts them alphabetically.
The only catch is that I can't use any Collection methods!
Please Help!
import java.util.Scanner;
import java.lang.Math;
import java.util.ArrayList;
class Main {
    public static void main(String[] args) {
        Scanner scan = new Scanner(System.in);
        String entered = "";
        ArrayList <String> unsortList = new ArrayList();
        System.out.println("Please enter some names");
        while (!(entered.equals("Stop"))) {
            System.out.println("Enter the next name:");
            entered = scan.nextLine();
            entered = titleCase(entered);
            if (entered.equals("Stop")) {
                break;
            unsortList.add(entered);
        System.out.println(sort(unsortList));
    public static String titleCase(String s) {
        s = s.toLowerCase();
        s = s.substring(0, 1).toUpperCase() + s.substring(1, s.length());
        return s;
    public static ArrayList <String> sort(ArrayList <String> toSort) {
      ArrayList <String> holder = new ArrayList();
      ArrayList <String> holder_2 = new ArrayList();
      ArrayList <String> sorted = new ArrayList();
      for (String ecx: toSort) {
        holder.add(ecx);
      for (String ecx_2: toSort) {
        holder_2.add(ecx_2);
      int c = 0;
      for (String test: holder) {
        for (int i = 0; i < holder_2.size(); i++) {
          if ( (test.compareTo(holder_2.get(i))) > 0 ) {
            test = holder_2.get(i);
        sorted.add(test);
        holder_2.remove(test);
        c++;
      return sorted;
And time is of the essence so please help!!!!!!!!!!
Main_2.java
I FIGURED IT OUT. NEVERMIND
Edited by Johnmakuta
I figured it out!
https://linustechtips.com/topic/575331-java-program-help/
Is title case is that every word is started by uppercase letter? If that's true then you just uppercase first letter of word, and if your names will be one word then it is fine, but if there is two words then only first be uppercase second will be lowercase.
Second thing is, I think what you're struggling with is sorting? You said you cannot use objects method, but you mean only sorting or compareTo counts to object method that you are not allowed to use?
You're creating a loot of new arrays in your sorting function, I see you remove some elements and add some. Sorting can be done just on original array. And I think you want use just set, and get on it, if you can use compareTo to compare two strings lexicographically then you would be home with some easy bubble sort or insert sort.
https://linustechtips.com/topic/575331-java-program-help/#findComment-7531468
	/* Sorts toSort by selection */
		int i, j, jmin;
		for(i = 0; i < toSort.size() - 1; i++)
			jmin = i;
			for(j = i + 1; j < toSort.size(); j++)
				if(isFirst(toSort.get(j), toSort.get(jmin)))
					jmin = j;
			Swap(toSort, i, jmin);
		return toSort;
	private static void Swap(ArrayList<String> toSort, int i0, int i1)
		String temp = toSort.get(i0);
		toSort.set(i0, toSort.get(i1));
		toSort.set(i1, temp);
	public static boolean isFirst(String s1, String s2)
		int minLen = Math.min(s1.length(), s2.length());
		for(int i = 0; i < minLen; i++)
			if(s1.charAt(i) < s2.charAt(i))
				return true;
			else if(s1.charAt(i) > s2.charAt(i))
				return false;
		return false;
Try this, I used the Selection Sorting.
https://linustechtips.com/topic/575331-java-program-help/#findComment-7536786
		int i, j, jmin;
		for(i = ; i < toSort.size() - 1; i++)
			jmin = i;
					jmin = j;
		return toSort;
		for(int i = ; i < minLen; i++)
				return true;
				return false;
		return false;
Why not just use String#compareToIgnoreCase? It returns
Quote
a negative integer, zero, or a positive integer as the first argument is less than, equal to, or greater than the second.
So instead, you could have the inner condition being:
if (toSort.get(j).compareToIgnoreCase(toSort.get(jmin)) < ) {
	jmin = j;
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/575331-java-program-help/#findComment-7540842
	jmin = j;
Yeah it isn't a collection method so it should be correct.
https://linustechtips.com/topic/575331-java-program-help/#findComment-7541958
include this code as a separate library then reference the release function() to find the values you need... let me know if it works... i've had these same issues before too... not fun
var fs = require( "fs" );
module.exports = function( Release ) {
	var
		files = [
			"dist/jquery.js",
			"dist/jquery.min.js",
			"dist/jquery.min.map",
			"dist/jquery.slim.js",
			"dist/jquery.slim.min.js",
			"dist/jquery.slim.min.map",
			"src/core.js"
		cdn = require( "./release/cdn" ),
		dist = require( "./release/dist" ),
		ensureSizzle = require( "./release/ensure-sizzle" ),
		npmTags = Release.npmTags;
	Release.define( {
		npmPublish: true,
		issueTracker: "github",
		 * Ensure the repo is in a proper state before release
		 * @param {Function} callback
		checkRepoState: function( callback ) {
			ensureSizzle( Release, callback );
		 * Set the version in the src folder for distributing AMD
		_setSrcVersion: function() {
			var corePath = __dirname + "/../src/core.js",
				contents = fs.readFileSync( corePath, "utf8" );
			contents = contents.replace( /@VERSION/g, Release.newVersion );
			fs.writeFileSync( corePath, contents, "utf8" );
		 * Generates any release artifacts that should be included in the release.
		 * The callback must be invoked with an array of files that should be
		 * committed before creating the tag.
		generateArtifacts: function( callback ) {
			Release.exec( "grunt", "Grunt command failed" );
			Release.exec(
				"grunt custom:-ajax,-effects,-deprecated --filename=jquery.slim.js && " +
					"grunt remove_map_comment --filename=jquery.slim.js",
				"Grunt custom failed"
			cdn.makeReleaseCopies( Release );
			Release._setSrcVersion();
			callback( files );
		 * Acts as insertion point for restoring Release.dir.repo
		 * It was changed to reuse npm publish code in jquery-release
		 * for publishing the distribution repo instead
		npmTags: function() {
			// origRepo is not defined if dist was skipped
			Release.dir.repo = Release.dir.origRepo || Release.dir.repo;
			return npmTags();
		 * Publish to distribution repo and npm
		dist: function( callback ) {
			cdn.makeArchives( Release, function() {
				dist( Release, files, callback );
module.exports.dependencies = [
	"archiver@0.14.2",
	"shelljs@0.2.6",
	"npm@2.3.0",
	"chalk@1.1.1"
https://linustechtips.com/topic/575331-java-program-help/#findComment-7549278
2 hours ago, canadiansteve2 said:
-snip-
His question is about Java, not JavaScript....
15" MBP TB
https://linustechtips.com/topic/575331-java-program-help/#findComment-7550068
