I just built my computer and im worried on temps. On Idle on medium fan settings (Define R5)  and using a CoolerMaster Hyper 212 EVO, my cpu is 24/24/21/19 degrees Celsius *i5 6600k at 3.5 - 3.9ghz (keeps changing)*. When playing CS:GO the temp goes to 44/45/37/38 degrees Celsius
My gpu AMD ASUS HD7950 DCII on idle is 45 degrees Celsius. When playing counter strike It goes up to max 60-69
Are these normal temps or should I be worried? (My 7950 is quite old, maybe 5 years now, and is slightly dusty inside but cant get to it)
https://linustechtips.com/topic/575279-cpu-and-gpu-normal-temps/
1 minute ago, AshleyAshes said:
It's normal for under load, for idle it is a LITTLE high compared to my 7950 machine but your setup might be a bit different.
Okay sweet as, thanks :)
is the CPU good for temps as well? What are good CPU temps?
https://linustechtips.com/topic/575279-cpu-and-gpu-normal-temps/#findComment-7530893
My 7950 idles at 42°C with a custom loop
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
https://linustechtips.com/topic/575279-cpu-and-gpu-normal-temps/#findComment-7530923
1 hour ago, ddrkreature said:
You actually have a decent bit of headroom. I've found that as long as you're below 85*C on both CPU and GPU, you're golden. My evga 970 oc ran at around 78-79c and never had an issue.
Yeah. Until you get a gaming laptop where all the internals chill at a toasty 85-95C since manufacturers tune them to sit as fast as possible RIGHT on the edge of the thermal throttling envelope. Its within safety parameters for the chips but makes me really uneasy :D.
PC:
Monolith(Laptop): CPU: i7 5700HQ GPU: GTX 980M 8GB RAM: 2x8GB 1600MHz Storage: 2x128GB Samsung 850 EVO(Raid 0) + 1TB HGST 7200RPM Model: Gigabyte P35XV4 Mouse: Razer Orochi Headset: Turtle Beach Stealth 450
IoT:
Router: Netgear D7000 Nighthawk
NAS: Synology DS218j, 2x 4TB Seagate Ironwolf
Media Accelerator: Nvidia Shield via Plex
Phone: Sony Xperia X Compact
https://linustechtips.com/topic/575279-cpu-and-gpu-normal-temps/#findComment-7531535
those are normal temperatures, perfectly fine :D
i7-7700 | Asrock H270M-ITX | Fractal Design Core 500 | 16GB Corsair Vengeance LPX | EVGA GTX 1080 Ti | 850 EVO 500GB | 850 EVO 250GB | WD CavGreen 2TB
EVGA SuperNOVA 550W | Steel Series Elite Prism | Final mouse 2015 | WASD Keyboards V2 (MX Blue) | Acer Predator 1440p 144Hz
https://linustechtips.com/topic/575279-cpu-and-gpu-normal-temps/#findComment-7532943
