Why pre-built? but at that budget I would look at refurbished
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/575246-help-choosing/#findComment-7530538
You could go so much farther with a custom built PC..
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/575246-help-choosing/#findComment-7530618
That is a horrible build through and through
https://linustechtips.com/topic/575246-help-choosing/#findComment-7532152
for that price, you can choose this for $740 instead. http://pcpartpicker.com/p/8TL2qs
https://linustechtips.com/topic/575246-help-choosing/#findComment-7532680
Bad PSU
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533032
8 minutes ago, don_svetlio said:
Bad PSU
How is this a bad psu?https://www.techpowerup.com/mobile/reviews/EVGA/600B/11.html
This shows a good result overall, only crossload 1 had failed ripple on the 5v rail.
http://www.amazon.com/EVGA-BRONZE-Continuous-Warranty-100-B1-0600-KR/dp/B00EON40CS
4.6 out of 5 stars with 1109 ppl, 78% 5 stars and 11% 4 stars
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=351
500w counterpart, got 8.4 score by johnny
So i really don't see how this is bad.
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533123
@STRMfrmXMN will explain why JG's testing is irrelevant
As for Crossload failure - that is a big deal as out of spec voltage can kill components
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533137
Crossload 1 test is where they loaded the 5v and 3.3v rails to max and leave the 12v alone. What part of the rig looks like it'll do that?
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533154
It's a low chance but possible - if the OP wants to go for looks with LEDs and other molex devices.
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533158
That gpu and cpu will keep the 12v rail up, crossload 1 won't happen unless you're using an old pentium rig. Most likely the psu will stay in 30-80% load- none of which failed ripple.
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533169
Actually, in idle - the +12V rail will be under less than 10% load so that's essentially Crossload
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533173
Well his testing is thorough but he does give too much credit to value which is why that EVGA scores about as good as a Corsair RM which is kinda backwards. The RM is pretty good (not the best) but is far better than the 500B.
I'd permit pairing a GTX 960 with a 500B but nothing more heat producing or power hungry than that as, if you're getting a GPU that powerful, you really can afford a better PSU.
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533540
And in this case the 305W no-name with a 950 and i3?
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533547
Maybe if they had a 750ti or some other GPU that didn't require external power, but for this, just gonna pass on the fire hazards.
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533570
Agreed.
https://linustechtips.com/topic/575246-help-choosing/#findComment-7533578
14 minutes ago, nV Guardian said:
I really can't build one and need a prebuilt
You can, just ask for parts. @herman mcpootis has done a build for you. Swap the PSU with a better one if you don't like it and everything will be great.
I need S340. But more Define S'ish
https://linustechtips.com/topic/575246-help-choosing/#findComment-7534452
