1 minute ago, zacbarker said:
I have thought about all the advice that I have received and an idea popped into my head. a high end gpu with a external PSU rigged up. no power coming from the actual computer but from the external power supply that is only powering the GPU. Hmmmmmmm
That's actually very possible. You can trick a PSU to boot and only power the GPU. You can do this by bridging a green and black wire on the 20+4 pin connector.
i like trains 馃檪
3 minutes ago, zacbarker said:
I was thinking just connecting the GPU to the MOBO with a riser and then connecting the PCI_e lead to the gpu
But the PCI slot, by itself, already provides 75w.
You'd have to Bios mod the card to not pull any wattage out of the mobo - that's doable, but I don't know if actually doing it would still make the GPU functional, or if it would cause an electrical problem, due to the card's design.
Want to help researchers improve the lives on millions of people with just your computer?聽Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
