I need 5v 2a to power a screen
Guest
I couldn't get anything to work to power a screen that goes with my raspberry pi. I tried an apple ipod charger which said it outputs 5v @ 2.4A, but that didn't work either. Would the usb cable I'm using be the problem possibly?
What are you connecting it to? Most any phone to wall outlet should be fine
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[i7-7700k@5Ghz | MSI Z270 M7 | 16GB 3000 GEIL EVOX | STRIX ROG 1060 OC 6G | EVGA G2 650W | ROSEWILL B2 SPIRIT | SANDISK 256GB M2 | 4x 1TB Seagate Barracudas RAID 10 ]
[i3-4360 | mini-itx potato | 4gb DDR3-1600 | 8tb wd red | 250gb seagate| Debian 9 ]
[Dell Inspiron 15 5567]
Raspberry pi tft screen, amazon says it runs at 5v 2a but when I try to use that it flickers on for a split second every few seconds
The small USB outlet chargers from Apple usually are only capable of 1amp unless your using the larger ones for IPads which I believe can give up to ~2.5amps. Try using another charger or a power adapter from the wall directly.
