Hello I have been trying to figure out why my motherboard won't stay on and post. I have everything plugged in correctly- check
Cpu is compatible- check
Every time I turn it on it turns on for 5 secones then off then back on and off and repeats infinitely. What can be the problem?
Bored is a GA-EX58-UD3R
https://linustechtips.com/topic/573266-wont-post-at-all-help/
check ram, and make sure motherboard connections are firmly plugged in
CPU: me | Dark Rock Pro 3 | Asus Z170-A | 32GB Dominator Plats | 512gb SSD/4TB WD Black | 980Ti | BQ Silent Base 800 | EVGA 850w |
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
BEST PC FOR THE PRICE:
$400 $500 $600 $700 $800 $900 $1000
If you want to Silence your PC/Room more, contact me.
https://linustechtips.com/topic/573266-wont-post-at-all-help/#findComment-7509595
Just now, silverjay928 said:
They all are and I have one 4 gig ram in
try putting the ram in a different slot. IF that doesnt work, but could possibly be your PSU
https://linustechtips.com/topic/573266-wont-post-at-all-help/#findComment-7509696
