Im upgrading my laptop CPU andI am curious if you think it can power the processor I want. I have a Dell Inspiron N5110 with an i3-2310m and I plan to upgrade to an i7-2630qm. Can my laptop handle the extra 10W it needs or do I need to step down to an i5?
Breaking things 1 day at a time
https://linustechtips.com/topic/573235-laptop-power-issues/
I don't know about you but the CPU in my laptop is soldered in place. Also, RIP your battery if you upgrade the CPU.
I'd upgrade to no more than an i5 if it's even possible to remove the CPU in your system as you don't know if the MOSFETs and all that can handle the extra heat.
https://linustechtips.com/topic/573235-laptop-power-issues/#findComment-7509324
If I am not wrong, your power adapter is 65W, so it should not be an issue with power, because on battery, no laptop will use its full potential. Heat is another issue, have you taken note whether your laptop can support the extra heat produced by the quad core processor? Is the heatsink beefy enough?
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/573235-laptop-power-issues/#findComment-7509334
From what I hear that i7 is supported by my laptop, so I would assume it would. I plan to find a way of ramping up my fans
https://linustechtips.com/topic/573235-laptop-power-issues/#findComment-7509404
For what those things cost, why don't you get a business class Dell to retrofit it into?  They typically have metal cases, so there's more heatsinking of the heat such a processor would generate (hence it would run derated less of the time).  Plus the inevitable replacement batteries you'll need to buy will likely be cheaper.
IMHO, uprated CPU's in laptops are usually not a good upgrade unless you get a die shrink out of it that meaningfully shifts the watts for performance ratio.
https://linustechtips.com/topic/573235-laptop-power-issues/#findComment-7510566
