1/50th the width of a thumb shouldnt be a problem.
i wouldnt get started on it without having metalworking experience and the necessary tools tho. steel is very had to work with. (i'd almost say you *need* a clamp to properly bend the steel)
https://linustechtips.com/topic/572833-psu-shroud-material-help/#findComment-7505588
30 minutes ago, KWelz said:
Why not use a sheet of Acrylic?  You can literally hang it off the edge of a table and heat it up to bend it.
I agree I would choose aluminum or acrylic over 304 stainless but this is annealed so it should bend OK the only thing I don't like about it is how crazy thin it is. This just flat will be more like a sheet of paper and make that cool noise when you hold it from one and and wave it back and forth
Rod
BSMods.com
Facebook
Youtube
https://linustechtips.com/topic/572833-psu-shroud-material-help/#findComment-7506961
9 hours ago, TravisB said:
Hello,
Can someone please tell .e if I'm able to purchase this at 0.018inch and bend it to a pau shroud?
http://www.amazon.com/dp/B000H9MVT2/ref=biss_dp_t_asn
Thanks.
Some guy on Reddit made this pretty nice PSU shroud.
Here's the link to the guide: https://www.reddit.com/r/pcmods/comments/3xl1w0/i_thought_it_would_be_a_shame_to_get_rid_of_my_r4/cy5wnkh
Hope it helps!
https://linustechtips.com/topic/572833-psu-shroud-material-help/#findComment-7507592
11 hours ago, TravisB said:
Hello,
Thanks.
As mentioned unless you have a metal brake you may not be able to get a perfect 90 degree bend with stainless steel but a more rounded corner since it's a fairly hard metal even though it is annealed.
https://linustechtips.com/topic/572833-psu-shroud-material-help/#findComment-7508142
