31 minutes ago, TravisB said:
Hello,
Does anyone know where I could buy Power Supply Dust Caps? I am thinking of buy Dust Caps for the EVGA Supernova G1 but any Power Supply caps that fit  other PowerSupplys will do fine.
Thanks.
What do you mean by dust caps if your talking an intake filter usually your case will have one that comes with it.
https://linustechtips.com/topic/572312-power-supply-dust-caps/#findComment-7500233
For instance. When you look at the evga psu I stated you have to connect the cables you will need to power your pc. I was wondering if there are any covers/plugs that could go over the outputs of the psu that I won't be using/connecting to/for my PC. I'll try and show an image.
https://linustechtips.com/topic/572312-power-supply-dust-caps/#findComment-7500361
6 hours ago, TravisB said:
Look at the PSU of this http://imgur.com/fJIpeHe I am looking for plugs like what is on this PSU can be any set of plugs for any PSU. Just want to know where to buy them.
I don't think I've seen anything like that before from my knowledge from looking around I see ones like theses but not for the connectors on the modular PSU itself.
http://www.primochill.com/product/mod-smart-6-pin-molex-dust-cover-black/
https://linustechtips.com/topic/572312-power-supply-dust-caps/#findComment-7501519
