I had the Corsair Air 240 and I wouldn't recommend it. It's way too loud because of the perforated intakes and it doesn't even have dust filters!
I would go for the Node 804.
I say jiggly-bytes when I see "GB".
It goes down better than you would expect.
https://linustechtips.com/topic/572106-best-small-matx-case/#findComment-7498479
