Good build, but have you considered an R9 390 instead? And also, is that PSU the "RMI" or the "RM"?
PC Build:
I5-6600K | Asus Z170 | 16GB Avexir ram | MSI R9 390 | Corsair 760T | 256GB SSD + 1TB WD HDD | Corsair 850 RMI | Dell U2515H
http://uk.pcpartpicker.com/p/Ck8VkL
https://linustechtips.com/topic/572075-build-question/#findComment-7498198
It is the RM, and I was considering a r9 390x, but I'm concerned about the heat. If I don't overclock, do you think the heat would be an issue?
https://linustechtips.com/topic/572075-build-question/#findComment-7498205
1 minute ago, ngvandyke said:
Is a 390x worth getting over a 390? Also what brand of 390 would you recommend?
Get a sapphire 390 and unless youre planning on 1440p get the 390X
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/572075-build-question/#findComment-7498215
You are spending the money the wrong way man, here's how i see it :
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($238.99 @ SuperBiiz)
CPU Cooler: ARCTIC Freezer 13 36.4 CFM CPU Cooler  ($26.88 @ OutletPC)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($5.95 @ Amazon)
Motherboard: ASRock Z170M Extreme4 Micro ATX LGA1151 Motherboard  ($118.98 @ Newegg)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  ($28.99 @ Newegg)
Storage: A-Data Premier Pro SP600 256GB 2.5" Solid State Drive  ($74.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($412.88 @ OutletPC)
Case: Fractal Design Define R4 Blackout with Window ATX Mid Tower Case  ($59.99 @ SuperBiiz)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($15.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($86.95 @ OutletPC)
Total: $1186.47
Generated by PCPartPicker 2016-03-26 18:40 EDT-0400
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/572075-build-question/#findComment-7498263
