Hi!
I have a problem with my computer.
The problem is that when I turn it on it loops 2-3 times before turning on and also when loading into specificaly WOW it sometimes freezes, could this be because of my motherboard not supplying enough power?
My motherboard is a Gigabyte GA-970A-DS3P.
I can't get any overclock either because then my computer will just shutdown.
I was thinking either buying a new motherboard like the new MSI 970 gaming, what I've read is that I should get a board with 6 powerphases and the board I have only has 4. It looks like the MSI 970 gaming has 8. I've looked at the Gigabyte GA-990FX-gaming to but I would like to have the cheapest board I can get.
The thing I want is in the future get a Z170 board with a 6700k so if the board is not a solution I can save up a little and get a Z170 and a 6100 with 8gb DDR4 in the meantime and save up for a 6700K later.
What do you think I should do? Or is the problem something else? It just feels like a power delivery problem.
https://linustechtips.com/topic/572031-amd-6300-problem/
It could be your power supply. Do you know what model it is?
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7497888
PSU shouldn't be the problem, I have a CX600 powering the FX-6300 on the MSI 970. If you aim at gaming, Intel is what you need. About your problem, I'm not sure, but it might be your mobo
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7497927
It take it you have not got any other PSU's to double check it is not your CX600M?
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7498010
5 minutes ago, baracken said:
No I'm afraid not, I through my old PSU out. All problems get worse if I overclock if that'a any help.
Yeah OCing would just make it worse if it is a power delivery problem. You could RMA your PSU back to Corsair. It just means you will be out of using your PC for a few weeks.
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7498071
11 minutes ago, baracken said:
problem is if it's not the PSU I will have to pay 50$ and it would not be worth it
You can just RMA it? I thought Corsair had warranty.
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7498250
one more thing I can say is that the motherboard only has an 4-pin connector for the CPU.
My feeling says it's the motherboard.
Let's say it's the motherboard, would it be more worth it to spend 350$ on a Z170, I3 6100 and 8gb DDR4 or 100$ on a new AM3+ motherboard with better powerdelivery?
I will not be able to upgrade the I3 to an I7 this year. If I go with a new motherboard I can upgrade my 750ti to something like an 960 or wait to get an 970.
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7502103
I remember reading about that specific motherboard and how it does poorly with FX6 and up cpus. So it isn't farfetched to say that it might be motherboard.
it might be worth it to get a Z170 board + i3 6100 now. Then next year upgrade to 1070 or R9 480/480X
Also, are you going to OC in the future for sure? Maybe you could instead take B150 motherboard and i5 6400/6500.
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7502224
34 minutes ago, baracken said:
My goal is to get the 6700k for some futureproof. I'm not sure yet, the B150 is just 50$ less than the Z170 I'm looking at.
I would like to OC in the future.
In that case, go for the Z170 + i3.
+ if you have the right BIOS on the motherboard, it means you can OC the i3.
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7502481
Thanks for the help, I'm pretty sure it's the MB.
Then I will try and get the money for that combo.
Then I will not buy any new motherboard for this system if I don't find one dirt cheap. It will be a month or 2 before I can buy the Z170+6100 combo.
This works for the time being, this thread was more if it was worth paying 100$ for a new mobo and a GPU or buy a new intel system.
I'm very thankful for the help. If I find a mobo cheap and get rid of the problems I will write it here so we have an defenite answer.
https://linustechtips.com/topic/572031-amd-6300-problem/#findComment-7503190
