Hi all
I've recently got a new monitor but when i connect it up to my graphics card it has a blue tint to it.
i already tried messing around with the monitor controls and all custom colours are turned up to max.
So i turned down the blue and the screen just got darker but still had the blue tint to it.
the monitor that i have is HP Compaq LA2405wg
all help is appreciated
https://linustechtips.com/topic/571957-display-help/
You could raise the other R and G rather than lower the B
Try the graphic card and computer display settings first
Check the cable and connection
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/571957-display-help/#findComment-7497136
