Fan question for H100i V2
Solved by W-L,
34 minutes ago, jslowik said:-SNIP-
The 4 fans should be the same in a push pull setup to prevent excessive noise and turbulence from different fans so if you only have two just setting it up either in push or pull would be a better option.
Featured Topics
3
2
joe_ollie909 ·
Posted in CPUs, Motherboards, and Memory8 -
DreamCat04 ·
Posted in PC Gaming1 -
saltycaramel ·
Posted in Tech News2 -
4
1
1
