Power Switches not Working
Go to solution Solved by Amazingasian,
32 minutes ago, NoLimitCrafting said:
Checked them all, I secured the motherboard, and cpu power connectors as well as the front I/O connectors. Nothing changed
Take it out of the case and try booting it on the MB box or something to make sure there's no grounding issues
So I had just cable managed my PC and when I went to turn it on, there was no response. I have proper power supplied to the system, my board's LEDs are lit and my case switches are plugged in. I even tried using the reset switch plug in the place of my power switch plug trying to get it to work. This led to no avail and now I am stumped. I also don't have a motherboard speaker to hear any beep codes that could be heard so I'm at a loss there too. Is there anything I could do to get my PC starting up again?
https://linustechtips.com/topic/571351-power-switches-not-working/
check your connections and make sure everything is seated properly
You know how it is, the cow goes "moo", the dog goes "woof" and the gamer goes "The PvP is unbalanced."
Personal Computer: CPU: i7-4790 Mobo: Asrock Z97 Extreme6 Graphics Card: MSI R9-380  Memory: 16GB (8GB x2) G. Skill Sniper Gaming Series PSU: Apevia Warlock 750W Case: NZXT Phantom 410 Series Storage: 240GB SSD (OS) 3TB HDD (data and such) 500 GB SSD (Movies and Large Data Transfers (I'm constantly moving this one around to other computers))
Go back to every cable you unplugged and make sure it's in all the way.  Especially the 24 Pin ATX, 8 PIN CPU and front i/o connectors.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
Just did that and there was an extra standoff under the board, I'll assume that's the reason why it didn't power on but the weirder thing is that it's been there for quite a while. Anyways, thanks a ton!
