what cpu would u recommend me to buy I7-6700k or I7-5820K or I7-5930K
i will be using it for everything from Auto Cad to 3D render to gaming and everyday tasks. please state the reason of choosing which processor. And no i don't have the option to wait for Q4 2016 unfortunately.
Also i will probs overclock
https://linustechtips.com/topic/571264-cpu-help/
3 minutes ago, ComputerScience911 said:
can u state the reason for ur choice i.e pros of it over the 6700k and the 5960k
2 more cores then the 6700k and doesn't cost a fortune like the 5960x.
My computers as of 2017/03
My Old PC
Dell Vostro 260 $150 2010
CPU: i3-2120@3.3Ghz, GPU: Intel HD Graphics 2000, ATI Radeon X1300, RAM: 4GB Axevir Budget Series, SSD: 240GB Radeon R7, HDD: random 250GB and random 160 GB, CASE: Crap from Dell, OS: Windows 7 Enterprise
My Current PC
Custom Build $1200 2016
CPU: i5-6600k@3.6Ghz, GPU: Sapphire R9 Fury, RAM: 16GB Geil EVO X, SSD: 240GB Radeon R7, HDD: Hitachi 500GB, CASE: Deepcool Kendomen, OS: Windows 10 Professional 64-Bit
Laptop
ASUS F8S $1150 2008
CPU: Core 2 Duo T7500, GPU: ATI 2400 Mobility, RAM: 8GB Mushkins, SSHD: 1TB Seagate Hybrid Drive, OS: Windows 7 Ultimate N and Windows 10 Professional
HTPC
MSi Cubi $200 2016
CPU: Pentium 3805u@1.9Ghz, GPU: Intel HD, RAM: 4GB Crucial DDR3L, SSD: 120GB Radeon R7
Other Laptop
HP 2210b $400 2009
CPU: Core 2 Duo T8100@2.1Ghz, GPU: Intel GM965, RAM: 2GB Hynix, HDD: Hitachi 160GB, OS: Linux Mint 17.3 and Lubuntu
*All Prices in the Canadian Dollar
https://linustechtips.com/topic/571264-cpu-help/#findComment-7490977
Please don't use that text color, it makes it difficult to read on night mode. Use auto.
That being said, 5820k, for the same reasons as the boi above me.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/571264-cpu-help/#findComment-7490988
At stock performance, most likely the i6700 will outperform 5820k for gaming applications.  5820k requires some OC/tweaking to make up for that shortcoming.
5820k allows for 3 way sli if you plan on going that route.  5930 and 5960x allows for 4 way sli.  I6700 will allow for only 2 way.
5820k has quad channel memory but most applications won't take advantage of that unless I think if you have a ton of background applications running at the same time.  That goes the same for the increased core count.
I chose the 5820k for my build.
https://linustechtips.com/topic/571264-cpu-help/#findComment-7491063
