Hi fellow techies,
I was wondering if there is a monitor arm/stacker plate that I can screw onto a monitor. The arm/stacker would have a pole attached to the vesa plate that I can screw another monitor onto. Something like a cheap, dual vertical monitor arm would also work BUT my desk depth is very limited and wall mounting is not an option.
Anything like this? If not maybe a good alternative? Horizontal monitors is not an option (again, limited desk space)
For all the smarta$$es, buying a new desk is NOT an option.
Hope you can help
- ReThorb_
https://linustechtips.com/topic/570773-vesa-stacker-mount/
http://www.amazon.com/Mount-It-MI-758-Adjustable-Panasonic-ViewSonic/dp/B005C2A3VW?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_search_detailpage
I got this one, relatively happy with it for the price. the "adjustable" or "free-float" ones won't get you a good vertical orientation no matter how hard you try (from experience, unless you spend for the expensive ones)
https://linustechtips.com/topic/570773-vesa-stacker-mount/#findComment-7487791
