mine is always off, but its plugged in. i think its a bit weird.
Have you reversed the polarity?
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772441
i think i followed the manual. but i dont care really, its just a flashing light, do you know if i can remove the power LED without it affecting anything?
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772448
he is sambd. he is a moderator, why would he lie?
I'm not a moderator ;)
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772461
I'm pretty sure that Samdb is correct, but why are you asking? I personally don't even plug mine in... unnecessary flashing lights annoy me. :P
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772466
@Samdb how do you know this? proof please
It just does, that's what it's for, I could take a video, but there isn't any point.
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772467
you could either disconnect it or cover it up, either way it's not an issue
its a bright damn light, it cannot be covered up, even with chemistry books, even though it should.
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772509
Easy test. Download a program that shows on Windows HDD LEDs for each drive. Now copy some big files inside one of the other drive than OS one. The LED on the program will flash and now look on the case itself. If it also flash similiar you got your answer. FYI - ive done that where my SSD was not doing anything and was copying a backup data folder of Fallout NV with A LOT added and modified files. Indicator on the case was going crazy aswell. Sh*t like that i do when im bored...
<p>Eryi's Action Rule#2 - "Dont jump on the green mushroom"
Ministry of StopIt!
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772743
@Ookami Samdb has already said its all drives that are installed in the computer...
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772758
Well. This question just sounds way too familiar.
What hdd in my system does the hdd activity led on the front of my case represent? Is it just C drive where the OS is installed or is it OS drive C and E which is my storage???
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772761
@Hazy125 from were?
@Ookami thanks
Was bored so added quotes and spoiler tags and stuff to say where from
https://linustechtips.com/topic/57075-hdd-activity-led/#findComment-772782
