weird 3570k clock speed
Go to solution Solved by Samdb,
It's perfectly normal, it actually helps reduce the EMI (Electromagnetic Interference) that a clock pulse generates, causing there to be less spikes and flatter curves. It does this by changing the frequency so a certain frequency is only used for a moment, in order to reduce the interference mention above. However, this may cause your system to become unstable or could have a lower performance than you initially intended, causing clock sensitive devices to be compromised. There may also be an option called "Smart Clock Speed" which does a similar job to spread spectrum, however it turn off the SDRAM, API and AGP signal when not in use, not to mention it also favours power consumption.
Sam,
Intel Response Squad member
http://bit.ly/IntelRally
hey guys. quick question for all you overclockers. im currently trying to oc my 3570k. i had stability at 4.1 with voltages around 1.12-1.13 temps were around 46 degrees idle and about 65-70 under load. (85 during prime95) well i noticed that for some reason in realtemp its showing my core speed at 4103.87.... now im somewhat new at oc. but that just doesn't seem right.... am i doing something wrong? help is much appreciated.
My Rig:
corsair 900d
3570k
corsair H100i
asus p8 z77-v le plus
24 gb crucial ballistix
asus gtx 660ti Direct cu ii oc
thermaltake TR2 600w
post-22998-0-01334800-1379362075_thumb.p
https://linustechtips.com/topic/57036-weird-3570k-clock-speed/
Software readings are not 100% correct. On top of that, clock speeds like that are 100% normal. Example: My 3570K is at 4.4GHz, but it's reading in CPU-Z is 4,423MHz.
https://linustechtips.com/topic/57036-weird-3570k-clock-speed/#findComment-771680
It's normal so don't worry about it :)
Intel i5 3570k | MSI GTX 670 Power Edition/OC SLI | Asus Sabertooth Z77 | Corsair Vengeance LP 16GB | Fractal Design Newton R2 650W | NZXT Switch 810 SE Gun Metal | BenQ 24" XL2420T 120Hz | Corsair K90  | Logitech G500 / Logtitech Performance MX | Sennheiser PC 360 | Asus Xonar DGX | NVIDIA GeForce 3D Vision 2 Wireless Kit
https://linustechtips.com/topic/57036-weird-3570k-clock-speed/#findComment-771825
It's quite normal to have those kind of numbers, but if it starts to go near or over 10Mhz mark from what you have set in bios, you might want to consider turning "spread spectrum" off if you haven't allready done so :)
1.PRIME X570-PRO/ 3700X & Custom H2O/H510 Elite/16Gb-RAM/RTX 2080 Super/500Gb M.2 ssd/240Gb ssd/4Tb/P-660 (XP²)/Win10
2.P5P55D-E PRO/i7-870@4,1Ghz@1,34V/Observatory/12Gb-RAM/RX 570 Strix/240Gb ssd/1Tb/RM650x/Win10
https://linustechtips.com/topic/57036-weird-3570k-clock-speed/#findComment-771899
Sam,
https://linustechtips.com/topic/57036-weird-3570k-clock-speed/#findComment-772004
My Rig:
corsair 900d
3570k
corsair H100i
The clock speed is normal but those temps are nuts, I would be remounting that cooler. at 1.272V my 3570k @ 4.5ghz only hit 86c on the hottest core after 4 hours of prime with a Coolermaster Hyper 212 evo. Your temps shouldn't be that high with a h100i at those volts.
i5-3570k @ 4.4ghz (1.240v) || Asrock extreme 4 || CM Hyper 212 evo
Samsung 840 || WD blue 1tb || WD green 1tb || Powercolor 7870 xt @ (1200 mhz core : 1500 mhz mem)
Powered by a silverstone strider 500w psu in a NZXT 210.
https://linustechtips.com/topic/57036-weird-3570k-clock-speed/#findComment-772165
fair enough. will do that today.
https://linustechtips.com/topic/57036-weird-3570k-clock-speed/#findComment-775465
