Hey guys adn gals
I`m looking for a new phone and therefor looking for a site that`s a bit like PCpartpicker, that lets you chose which parts you expect to get from your phone and thereby get what you`re looking for.
You guys/gals know anything like it? Thanks
to game or not to game, that`s the question
https://linustechtips.com/topic/570130-pcpartpicker-for-phones/
https://www.android.com/phones/whichphone/#/
google created this site, its only for android and idk if the phones they choose are up to date
not very technical, just a general overview of usage
if i post a link to amazon try to use the LTT affiliate code to help the channel http://www.amazon.com/?_encoding=UTF8&camp=1789&creative=390957&linkCode=ur2&tag=linustechtips-20
https://linustechtips.com/topic/570130-pcpartpicker-for-phones/#findComment-7479860
There's a dutch site: tweakers.net (already set to smartphone for ya.) I love this site, you can really adjust what you want.
In the left pane you just select what you want and it shows the phone's that have it.
Use google to translate the site. (right click anywhere and select "Translate to english" if you're on chrome)
CPU: Intel i5-3470
GPU: MSI GTX 780
OS: GNU/Linux.
https://linustechtips.com/topic/570130-pcpartpicker-for-phones/#findComment-7479873
http://www.phonescoop.com/phones/finder.php
there is also this site
https://linustechtips.com/topic/570130-pcpartpicker-for-phones/#findComment-7479874
hahah dankje :)
https://linustechtips.com/topic/570130-pcpartpicker-for-phones/#findComment-7479881
  • 6 years later...
You can.. unfortunately then the results are zero.
..and I didn't even get to the point where I want dual sim and an sd card.
EDIT: Found this: https://www.productchart.com/smartphones/
https://linustechtips.com/topic/570130-pcpartpicker-for-phones/#findComment-15439954
