3 minutes ago, PCHelp2015 said:
Here are his specs: He wants to be able to live-stream but apparently his PC is too slow to run (Twitch).
His Budget: £200
What should he upgrade?
What cpu is he running? EDIT: What games does he livestream?
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
https://linustechtips.com/topic/569784-friend-needs-help/#findComment-7476484
http://uk.pcpartpicker.com/p/W2Wfqs
He should need that to livestream, But he will need to upgrade his gpu in future to run more hardcore games
  • Case: NXZT S340
  • PSU: EVGA 650G
https://linustechtips.com/topic/569784-friend-needs-help/#findComment-7476507
16 minutes ago, PCHelp2015 said:
Nothing, save up for a new PC, though buy a Hyper 212 EVO, 96C ain't good man
also you can use DXtory to grab the footage and take some load off your CPU
x
https://linustechtips.com/topic/569784-friend-needs-help/#findComment-7476548
His Budget: £200
CPU to intel, mobo, and get a gpu. This however, will not be able to be accomplished on a $200 budget.
https://linustechtips.com/topic/569784-friend-needs-help/#findComment-7476559
