Hello everyone.
I gave my son my G3258 OC @ 4.2ghz and GTX 960.
When playing GTAV, the PC stutters when vsync is not set to 1/2.  The frame rate fluctuates between 30-70fps.  I guessing the PC will do fine with a 45 fps settings.
45 fps is better than 30 fps.
Now my question is, Does a program exist where I can lock the frame rates to what ever I set it to?  I'd like to lock it in at 45 fps.  I don't want to upgrade cpus for the ONE game that doesn't play nice.
https://linustechtips.com/topic/569767-frame-rate-limiter-nvidia/
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Your issue is the CPU. It won't fix it to limit the fps, you need 4 threads
I know that.
The stuttering is due to the fluctuation of frame rate.
It doesn't stutter when locked at 30.
It stutters when allowed to fluctuate between 30-70fps.
I figure the cpu is capable of something in between 30-70.
45 fps is still far more enjoyable than consoles without having to upgrade the cpu.
8 minutes ago, max_headroom said:
I know that.
Have you tried locked 30?
Is that the pnly game he plays? If he decides to start playing others i think you will want to upgrade the CPU anyway. I'd get a 4460 now before price goes up due to scarcity since skylake is becoming more prominent.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
