Hi I have an AT2020 and It needs phantom power, any suggestions?
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
    Thermaltake Core V21
  • Storage
    1TB HDD, 700gb HDD, 320gb HDD and 256gb SSD
  • PSU
    Corsair CX600
  • Display(s)
    Flatron L1960TR , MAG MS776I , ViewSonic VA903m ( all of them are 1280x1024,dad found em) and a Fujicom FJ-32V TV
  • Cooling
    1 200M front fan, and unknowen CPU tower(low profile)
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
    Jamo E 4 CEN, Jamo E470 and Jamo E410 with a KENWOOD S505D
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/569727-cheap-phantom-power/
Focusrite solo
blue icicle
behringer mixer
etc etc just go on amazon and type in phantom power :)
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475857
I think the Blue Icicle will provide power. It basically converts your XLR mic into a usb mic without sacrificing the extra quality of an XLR mic... I think.
ASU
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475862
I can testify for the Blue Icicle - I've used it with an AT2020 too and it worked great.
Hi! I'm Josh. You'll most likely find me browsing audio, GPU's or occasionally something else.
I'm a cinematographer - I've done work for loads of people including politicians like Gordon Brown, David Cameron and more!
Render Machine - Work Machine
  • Fully Spec'd Mac Pro (12-Core, Dual 6GB D700s, 64GB RAM) (£7779)
  • Monitor: 1x Sony 4K OLED Critical reference display, 2 x Apple Thunderbolt Display (2560x1600) (WAITING ON 4K / 5K Thunderbolt Display <333)
Laptop - Daily Driver
  • Fully Spec'd MacBook Pro (4-Core i7, R9 M370X, 16GB RAM, 512GB SSD) (£1999)
Windows Machine / Hackintosh - Personal Rig
  • Intel Core  i7 3770k Water-cooled @ 5.4 GHz (been going for 2+ years)
  • Corsair H80i (with SP120's)
  • EVGA SC+ ACX2.0 nvidia GTX 980 Ti 6GB GDDR5 GPU Overclocked slightly.
  • 16GB HyperX Fury Black 1866MHz DDR3 2x8
  • MSI Z77 MPower ATX Socket-LGA1155 Mb
  • 2 x Dell UP2715K 5120x2880 IPS monitors (scaled down for games) (and more monitors but I only use them periodically)
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475869
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475877
A USB condenser mic preamp should do. After all, the AT2020 is most popular when sold in a bundle that includes one of those.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475894
my friend gave it to me when he left the country without the cables or anything...
and I cant really buy from amazon.(SINCE ISRAEL AND IMPORT+SHIPPING IS REALLY HIGH)
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475905
You can probably find a USB to XLR cable somewhere. Just make sure it has more than just the cable on it and that it's rated to supply the +48v of phantom power the AT2020 needs to work.
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475962
so anything that accepts A +48V of phantom power and XLR is good enough?(if i find an amp or sumthin like dat)
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475972
Anything that's rated to provide +48v phantom power to a microphone. Behringer makes a ton of cheap mixers that should be fine if you just want a signal from a microphone and nothing particularly fancy. If you're savvy enough, you could probably build the circuit yourself using an external power adapter for the phantom power and a line-level auxiliary output to go into the microphone input port on your computer.
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475978
il try to find a behringer EQ since EQs are fun!
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/569727-cheap-phantom-power/#findComment-7475993
