Okay i have a 980 ti classified and i'm new to overclocking. I followed Linus Tech Tips guide to overclocking GPUs to the letter and also Referenced Jays2Cents video also. i was getting great overclocks of like 250 to 270 for core clock until it crashed at 280. Was stuck on black screen but followed instruction and turned of PC to get back to desktop. Turned over clock down and suddenly next benchmark i was getting FPS of like 30 to 40. Like WTF, it think for some reason i have a core clock of only 450 and Memory clock of 450. Uninstalled MSI Afterburner and reset Navidia Control panel to default then rebooted Pc and it went back to normal FPS but CPU-z still says that same core clock of like 595 running 3D applications profile. I Need Help if anyone can help me out. I just want it back to normal and to never download MSi afterburner ever again.
https://linustechtips.com/topic/569586-980-ti-overclocking-problems/
Why dont you just switch it back to it? You know overclock it back to default and then leave it alone.
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
that sounds like digging a hole to the surface when you have already fallen into a hole, mostly when i have so soundly proven i messed things up :/ i think i'm going to uninstall and reinstall its navida driver. This Forum seems to be the exact problem i am having but with a 980 ti instead of a 970
http://www.tomshardware.com/answers/id-2708540/gtx-970-clockspeed-stuck-540-mhz.html
Im sure its just your Driver that is fucked up after the OC. Just reinstall it and you will be fine.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Also, keep in mind that sometimes CPU-Z won't show the correct clocks. Use Afterburner or HWMonitor. Other than that at this point it seems your drivers got borked so yeah try going clean and see if that fixes it.
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
update i used DDU installed new driver and everything returned to normal except for one thing. it wont do close to the overclock it was pulling before. It lost about 150 in core clock and memory i havent tried yet. During the first overclocking session i didnt touch voltage and also temps never went over 70
What was the max frequency you were hitting before and what is it now?
+270 sounds rather high, like the card was trying to go to a boost clock of 1,600 or more, which would be a very aggressive overclock.
+150 sounds like a more reasonable overclock (around 1,500 I'm guessing).
