Just now, jeonjaeng said:
As far as i know the skylake CPU's dont come with a cooler, i might be wrong if so i will take it off.
as @Aytex more ram
only the K ones don't come with cpu, click on the cpu and scroll to cpu cooler it says "includes cooler" "yes"
Can't remember if they do or not but if they do then yea, I'd drop the cooler. Otherwise the system looks good to me.... Apart from the ram... I'd do like everyone lse says and go ahead and go with the full 8 gigs as it won't hurt. :)
Just now, Arty said:
as @Aytex more ram
I got that also since it is just for basic computing i did not see a need for 8 GB. Also its a faster speed ram than normal DDR3
doesn't matter what your doing
8GB of ram should be standard,
24 minutes ago, jeonjaeng said:
This build is for basic computing and online stuff... What are your thoughts? http://pcpartpicker.com/p/xbZPt6
What are you intending to actually do this thing. Is there a specific reason why you are building?
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
Hmm... Seems overkill to do just basic web browsing.
Just grab the guts of a W95 computer and put an SSD in it. :3
1 minute ago, jeonjaeng said:
I may look into the case however there is no need to get the upgraded ram, no gaming being done on it, also gotta pay for dem taxes
Ya switch the ram. I recommend using the WDCB HDD tho because Barracuda drives are unrealiable and have a bad failure rate. Its like only $4 more so why not.
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
got the hard drive changed, but there is no real big computing being done on the computer so is there really even a need to upgrade the ram, also it will put me over the budget due to taxes... :{ New York State :'(
You probs should get it though because it will give you alot more performance even in everyday ordinary tasks.
you can spend less if you don't have to play games or do other hard things..
with an ssd even a core2duo will be good , 90% of times when a pc is slow, even with daily tasks, it's because the hdd is slow
Pentium G4400
http://pcpartpicker.com/p/6qxCsY
or AMD  A8-7600
http://pcpartpicker.com/p/WhRhnQ
in all 2 build i put in a seasonic bronze psu, very reliable.
Intel or AMD is your choice, for that price AMD is a bit better.
Drop the CPU cooler, and get 8gb of ram. The i3-6100 comes with a stock cooler and that is good if your not gaming. Balls I even have a gaming PC that is using the stock cooler and it does not have much different temps then the aftermarket cooler.
Duh_Tech
I am a computer and aviation enthusiast. I have a good enough PC.
