Premiere Pro + VM doesn't work
Go to solution Solved by tt2468,
6 minutes ago, WhatComesAround said:
So I have created a VM that I would like to have someone edit videos from but I have found a bump in the road. Theres this error that says something like " Graphics Drivers need to be updated" and so that made me wonder about what I should do because I don't really have a graphics card assigned to it (if that is possible) (I am using Virtual Box) and so I am not sure on what to do, any help is really greatly appreciated. :D
Don't use a vm unless you are giving the vm a physical gpu. Virtualbox does not support this.
https://linustechtips.com/topic/569196-premiere-pro-vm-doesnt-work/
My native language is C++
