So i have about 500$ laying around and from how amd has things priced right now. **Not saying that zen will be priced the same**
Should I wait for zen to come out and  get their mid high range cpu equivalent to the 8350 and get a good overclocking mobo or upgrade my system to the z170 or x99 platforms.
desktop amd fx 8320 10gb ram ocd to 1866, 1tb segate hdd 500gb  toshiba 250 gb segate 60gb ?? 240gb trion sdd xfx amd radeon 6570 750 wat dual 12v rail ultra psu asus M5A97 R2.0
https://linustechtips.com/topic/568818-amd-zen-system/
waiting is always the better option, because it always depends on if you need the extra performance
personally, i'd wait since your cpu is pretty normal and it won't hurt you to wait :)
and ofc: the zen cpus could be really good ;)
https://linustechtips.com/topic/568818-amd-zen-system/#findComment-7466825
Depends how bad you want/need a pc. If you already got one then just wait, there supposed to be out at the end of the year.
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
https://linustechtips.com/topic/568818-amd-zen-system/#findComment-7466831
