3 hours ago, GeorgeKellow said:
I have a asus gtx 960 strix (2gb). I want a little bit more performance for my money, should I sell that card and buy a 4gb r9 380?
EDIT- if I did get another card it would be the MSI 4GB model
Check the compatibility. First get a stable quote for what you will sell the 960 for and then look for the card. Get the card using your own money and if everything turns out okay then sell the 960... If it does not, then return the 380.
https://linustechtips.com/topic/568817-small-upgrade/#findComment-7466815
I could get about £110 for it :P
https://linustechtips.com/topic/568817-small-upgrade/#findComment-7466823
R9 380 is somehow like GTX 960
Just like R9 390 is somehow like GTX 970
I would spend a bit more money and get 970 or 390.
I don't think it's worth to go from 960 to 380, but that's just my opinion.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/568817-small-upgrade/#findComment-7466866
since they are of the same class (price range and performance wise)
it's not worth to sell the 960, the performance diffrence is not worth it for the premium you are paying because you are selling your 960 and you will get less than retail
https://linustechtips.com/topic/568817-small-upgrade/#findComment-7466867
