Computer keeps crashing after an preriod of tim i just recently installed new gpu
CPU:Intel Core i5 6600K 3,5GHz  Motherboard: Z170 PRO GAMING  RAM: HyperX X Fury black DDR4 2x4GB
GPU: AMD Radeon HD 7800 series Case: some random shit tho it is gonna be upgraded Storage: SanDisk SSD Plus 240GB Cooling: Cooler Master Hyper 212 Evo Display: Asus VS278Q Keyboard: Roccat Arvo Mouse:Razer Naga 2015 Edition OS:Windows 10
https://linustechtips.com/topic/568595-problems-with-pc-help/
1 minute ago, chiwas said:
Does it crash on idle or only when you're playing games? Whats your PSU and that new GPU?
Its an xfx 7800 keep in mind this is an old pc aswell its an corsair psu and an amd chipset it crashed while watching stream and sownloading drivers
https://linustechtips.com/topic/568595-problems-with-pc-help/#findComment-7464575
3 minutes ago, ben dover kid said:
check event viewer criticals
Its on swdish tho : s
https://linustechtips.com/topic/568595-problems-with-pc-help/#findComment-7464589
check the bugcheckcode.
https://linustechtips.com/topic/568595-problems-with-pc-help/#findComment-7464609
darn. bugcheckcode 0 means that your pc has no idea why something went wrong. i had that problem for months. new psu fixed it. im sorry i can't help you further than this, new psu might fix the problem. but also you don't need to get scared if this happened only 1 time. sometimes pc can just randomly shut down. if this starts to be regularly like every day(but check the bugcheckcodes every time), then get the new psu.
https://linustechtips.com/topic/568595-problems-with-pc-help/#findComment-7464658
Ok thanks
https://linustechtips.com/topic/568595-problems-with-pc-help/#findComment-7464662
