Hey everyone,
A couple months ago I ordered myself an MSi M7 motherboard, an i7 6700k and 32gb of Corsair Vengeance RAM. I decided this week that I would finally put it all into my system and use my current CPU cooler. It starts up fine but won't do finish any Intel updates that I've downloaded. It'll get to about 90% and go unresponsive. Computer runs extremely sluggish and won't turn off or restart without my holding the power button down on the tower.
Please help, I've been trying to figure all this out tonight and I think I'm already losing hair.
CPU:i7-4770|Motherboard:Asus Z87-A|RAM:G.Skill 2x8GB|GPU:EVGA GTX780 x2|Case:NZXT Phantom 820|PSU:EVGA 1000W|Monitor: LG 34UC97
https://linustechtips.com/topic/568424-upgraded-tonight-nothing-but-problems/
Did you look at the temperatures of your hardware?
What about the Windows installation? is there anything wrong with that?
Me: Computer Engineer. Geek. Nerd.
[Educational] Computer Architecture: Computer Memory Hierarchy
[Educational] Computer Architecture:  What is SSE/AVX? (SIMD)
1 minute ago, airdeano said:
OS?
what intel updates?
have you set the UEFI/BIOS to default settings?
Sorry, Windows 8.1, chipset update and audio drivers.
Temps are normal, if not lower than before. Still using 8.1 installed on a Samsung 840 pro.
Is it a clean install? If not then you will have to manually remove all the conflicting drivers from your old motherboard and fix any other conflicts you come across.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
usually, the chipset needs .NET and installs this as well.
when it initializes on install, it'll prompt a restart. after reboot, it'll complete the installation. which part hangs?
any other SATA drives installed (USB OS?)
^ This.
otherwise, try booting from safe mode and uninstall all the drivers manually (normally its just easier to do a clean install)
4 minutes ago, Wander Away said:
^ This.
That might be the problem. Where am I able to find all of the old drivers?
all the drivers are here: https://us.msi.com/Motherboard/support/Z170A-GAMING-M7.html#down-bios
install after OS is fresh:
01 chipset
02 intel engine management
03 lan
04 USB 3.0
05 audio (optional)
06 dedicated GPU/iGPU (if needed)
Most of it can be found under control panel>programs>programs and features
Finding the correct items to uninstall however... can be a pain
