Overclocking Ram help
Go to solution Solved by Imakuni,
9 minutes ago, Dimas said:
Hey guys, So I recently got back at it again on tweaking my personal rig and I was going through the Internet and I found my motherboard spec sheet and ram support. So apparently my motherboard supports ddr3 (duh) at 3000mhz obviously overclocked. Okay so now here comes what I want to do I want to over clock my ram but not to that extend I want to overclock it so I can see noticible results or at least a safe overclock that can give me an extra performance boost in my PC overall. I know I won't get much out of gaming but I don't game that much, I don't even have a GPU but here are my specs
motherboard: GA-z87-D3HP
CPU: Intel i5 4670k (overclocked 4.4Ghz 29% overclock not too shabby with H100)
 ram: Kingston hyper X (8gbs) ddr3 1600Mhz
So here is basically my main components I don't feel the need to bore you with what kind of SSD's I'm running or hard drives. I just want a straight forward answer on whether it's actually feasible or not; and if it is how can I achieve it and how high should I set my multiplier and still be safe.
Thank you!
Quite the opposite, if you are using the iGPU, you will gain quite a lot from RAM OCing!
But anyway, here. This should be better than a wall of text.
Thank you!
I replace your reality and substitute my own.
https://linustechtips.com/topic/568349-overclocking-ram-help/
Thank you!
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/568349-overclocking-ram-help/#findComment-7462076
Thank man real helpful guide
https://linustechtips.com/topic/568349-overclocking-ram-help/#findComment-7462204
