mobo plug-in power?
Go to solution Solved by SeanAngelo,
4 minutes ago, noisebomb44 said:
So this is kind of strange to me, but when using microphones such as the "ECM-CS3" you apparently require good "plug-in power" in order to make it work better (aka louder sound, less noise, etc), but i just want to plug it straight into the motherboard, how do i figure out if my motherboard supports the power the mic draws in its 3.5 port?
it will have enough power.
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/568286-mobo-plug-in-power/
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/568286-mobo-plug-in-power/#findComment-7461350
