Just now, Chewique said:
I am looking for some decent led strips for my desk! any suggestions? (im from the uk)
If you want to DIY something you can get rolls of LED's off Amazon and wire them up, they are a fairly low cost solution and not to hard to wire up. If you want predone solutions like for PC cases both AddonCustoms and Cable Mods both make get LED kits.
-Moved to Modding Section-
https://linustechtips.com/topic/568244-led-recommendations/#findComment-7460944
Thanks <3
MY RIG
I5 6600k
16gb Corsair vengeance 2666mhz
MSI Gaming X 1070
WD blue 2tb
samsung 850 evo 250gb
EVGA supernova G2 650w
https://linustechtips.com/topic/568244-led-recommendations/#findComment-7460953
