My cpu is usually at 90 - 105 degrees celsius while running speccy (what i use to look at hardware temps) and skype, was wondering if anyone could help me out a little? its a 2015 lenovo z50-75 with a amd kaveri A8-7100 cpu and radeon r5 gpu (i needed a new cheap laptop and this was the cheapest i could get that suited me) help is very much appreciated.
https://linustechtips.com/topic/567985-overheating-at-idle/
I will suggest cleaning the CPU fan and reapplying thermal paste if you can, those temperatures are horrible. Are you still in warranty, if so just send it in and save yourself the hassle.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/567985-overheating-at-idle/#findComment-7458667
Those temps are absurd - the CPU should be shutting down at 90*C
https://linustechtips.com/topic/567985-overheating-at-idle/#findComment-7458684
