Hi,
I need a power bank for my xps 13. I didn't want that dell one, because I found higher capacities for the same price. Because I'm not sure about voltage (I don't have a notebook right now) so I'm asking you about some high capacity model that can charge my xps 13.
Thanks.
https://linustechtips.com/topic/567714-power-bank/
Just now, smolkomartin1 said:
Hi,
Thanks.
Depending on the voltage and amperage of the laptop you can check via the power adapter. Units like theses will work but if the laptop's current draw is more than the unit it won't be able to keep up say while at load: https://www.anker.com/products/79AN20L-SA
https://linustechtips.com/topic/567714-power-bank/#findComment-7456377
