4 minutes ago, Hadokken said:
looking for some builds that can game high grafic and stream to twitch at the same time.
I have peripherals and my budget is ~2500USD
Best Regards
Hadokken
Alright, give me a minute, do you need the OS?
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
Best Regards
Hadokken
There is no need to spend more then 2k. Also you dont need 32gb of ram but ram doesnt cost that much so meh. Maybe upgrade the SSD to a one terabyte if you want. I left headroom if you want to add another 980 ti to the build, you can easily do it.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($369.99 @ Newegg)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($139.99 @ Newegg)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  ($173.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 32GB (2 x 16GB) DDR4-3200 Memory  ($149.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($149.89 @ OutletPC)
Storage: Western Digital BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive  ($154.95 @ SuperBiiz)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($659.95 @ B&H)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($118.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA 1000 P2 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($169.99 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.99 @ NCIX US)
Total: $2164.72
Generated by PCPartPicker 2016-03-18 12:17 EDT-0400
Total: $2164.72
Really full price for an os? Who pays that much anymore? http://www.kinguin.net/category/22175/windows-10-home-oem-key/
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
This should work just fine, has storage the speed of these fancy Intel 700Series SDDs, brings along a lot of upgradeability and will be about as quiet as a non custom water cooled high end pc will get
http://pcpartpicker.com/p/FzZXCJ
EDIT:
The main difference to the other guy's builds is that this one has 2 980tis (thus being a little over budged). If you can't afford that, go with a cheaper 2x8GB RAM solution and/or downgrade the storage solution a little
Edited by ChalkChalkson
1 . His budget is 2500$
2.  Im not even sure that he needs an OS
3. Places like that can screw you over
Thats why you buy the protection duh. You gotta be an idiot if you get scammed because you didnt want to pay the extra dollar.
ok, you get scammed. Enjoy the headache of contacting support. He can afford a full windows license with ease, why does it matter? Its not like he has a tight 400 dollar budget.
Just cause he has a big budget it doesnt mean you need to make him pay for what he doesnt need. You guys are building pc that are overkill.
i... he said his budget was 2500 dollars. What do you want like fuck dude. I didnt even use the full 2500. If someone asked for it ill deliver...
You can go ahead and get whatever these guys are suggesting to you but my build is really all you need and still this is kinda overkill. Even though you have a big budget it isnt wise to spend it all because you can spend that money in other places. http://pcpartpicker.com/p/2DkHYJ or you could go with the newer generation http://pcpartpicker.com/p/qjBzbv. I assumed you arent going to be playing at 4k but if you were to then go for a 980ti.
A budget is a max ammount of money to be spent. Just because its big it doesnt mean you need to suggest shit he doesnt need.
