2 minutes ago, Keatodylan said:
Im helping my friend buy parts and build a $700 gaming pc and i wanted your guys advice we are looking to go for an Intel Cpu and Nvidia GPU preferably
cpu g3258,gpu gtx 970, any motherboard that will support the lga 1150 sockettype, for storage you can go 256gb ssd, 128gb ssd + 1tb hdd, or just a 1tb hdd, your choice depending on budget, for a case, this is mostly preference so just go on pcpartpicker and filter through some of them, for a budget case I can recommend the source 210, anything by fractal design or corsair, and if you want to spend a bit more on the case, I LOVE the define R4, for a PSU pick a psu that is above 500w, at least 80+ bronze, and not from a manufacturer like diablotek.  I would stick with corsair, thermaltake, evga, and coolermaster for psus.  I hope this helped, let me know if you have any other questions
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7448923
Are you high? Lol.
a G3258 and 970 is literally the worst combo ever. You can definitely fit an i3 and 960 4GB or maybe even a 970
Welcome to LTT! Feel free to PM me if you just wanna chat, I love conversation!
If you ever have any audio questions, wether it's software, hardware, or production and theory, feel free to ask me. Odds are I can help you, or get you help.
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7448949
4 minutes ago, Derpologist said:
Are you high? Lol.
If its for gaming, the gpu is more important. Go 970, and try to get the best CPU you can.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7448984
Are you high? Lol.
whats wrong with a 3258 and a 970, he said he is using this for gaming.  sure you could fit in an i3 and drop the gpu down to a 960 but there will be no gains in his gaming performance, in fact, he will lose performance.  Sure, if he has skype chrome and a music player open, he will see a performance dip in game, but with a 700$ budget, you will get the most performance out of the 3258 and the 970 if you are conscious about your cpu usage.
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7448994
Yes, of course if he can you can afford the i3 get it, I was just trying to work within the 700$ budget.
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7448999
Here. http://pcpartpicker.com/p/DMJnRB
If you want to save some money, get an r9 380. I know you said you want to go nvidia, but you might just have to suck it up.
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7449030
Prices from Amazon
Intel I3 6100                                    122$
Gygabyte 1151 ddr4 Motherboard    60$
16 gb ddr4  Kingston Fury                70$
GTX 970 4gb                                  300$
Crucial 240gb SSD                           65$
Seasonic 520W Bronze                    59$
The Case you want                          40$
                                                       716$
for 800$ you can buy a bigger ssd (55$ more) or I5 6500 (83$ more than I3) if he want a real quad core,
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7449053
Just now, vtecf20c said:
Prices from Amazon
Intel I3 6100                                    122$
GTX 970 4gb                                  300$
                                                       716$
This is also a very good build (arguably better than mine I posted a short while ago), great job on it.
Although in the future, just a small thing, I'd suggest using something like PCpartpicker. There's a feature to make only amazon (or other shopping places) prices show up (I forgot how to do it lol, but I know its there)
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7449063
your build is very good for a normal pc, because of the I5 and TB drive, but in game 970 is a lot better.
i will use pcparticker next tipe
https://linustechtips.com/topic/567044-building-pc-700-800/#findComment-7449098
