Hello there,
My main monitor is a 1080p monitor that's connected to my computer using DVI, the only connection that's availble on that monitor.
Since GTA V is coming out, I have a reason to dust off my ps3 and play a game on it again, but I don't like playing in front of a TV anymore, so I'd like to connect the ps3 to my monitor. But my monitor does not have HDMI and doesn't have built-in speakers. Is there a way to "split" the DVI connection (I only have one at the monitor) so I can connect both my pc and the ps3 to it, and the ability to choose what input to use? And then a hdmi to dvi-converter that also has an audio output on it so I can connect headphones or speakers to it, since I need sound obviously?
I've tried making a sketch in paint for clarification:
Also, if this is possible, will my monitor (when using the pc) have any more input lag because it goes trough that switch?
Thanks!
i5 4670k - MSI GTX 770 gaming - Fractal design define R4 (windowed) - MSI Z87-G45 gaming - be quiet! Dark Rock Pro 2 - Corsair vengeance 8 gb (lp) - WB black 1tb - 256GB SSD - Corsair TX 750M - Ducky Shine 3
https://linustechtips.com/topic/56697-dvi-ps3/
I don't think such a switch exists.
If you had HDMI on the monitor than you could get this http://www.amazon.com/dp/B009CHRLOA/ref=asc_df_B009CHRLOA2646534?smid=A1IZYUD9B8EI1C&tag=nextagusmp0357663-20&linkCode=asn&creative=395105&creativeASIN=B009CHRLOA
But I can't find anything with DVI/HDMI in and DVI out.
With that you can maybe get a HDMI to DVI adapter for the monitor than plug your PC and PS3 into the switch.
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
https://linustechtips.com/topic/56697-dvi-ps3/#findComment-766322
Does the speakers use a 3,5 mm connector?
If so you can use the stock RCA cables that came with the PS3 and adapt them to 3,5 mm(a adapter like this: http://www.amazon.com/3-5mm-Stereo-Plug-Dual-Adapter/dp/B0002KR5Q0)
And then use a DVI-splitter like this: http://www.amazon.com/Monoprice-2x1-Enhanced-Powered-Switch/dp/B001TKPMZ8/ref=sr_1_1?s=electronics&ie=UTF8&qid=1379268487&sr=1-1&keywords=dvi+switch
You'll also need a HDMI-DVI cable
https://linustechtips.com/topic/56697-dvi-ps3/#findComment-766360
https://linustechtips.com/topic/56697-dvi-ps3/#findComment-766540
I think I'll just manually change the dvi cables when choosing between pc or ps3 usage, since I don't want to spend too much.
So the hdmi to dvi cable outputs the display and the other output in the ps3 for audio only?
https://linustechtips.com/topic/56697-dvi-ps3/#findComment-766556
Yes but you'll have to configure the PS3 to output the audio to the RCA plugs.
https://linustechtips.com/topic/56697-dvi-ps3/#findComment-766564
