http://www.aria.co.uk/Products/Cables/DVI+Monitor+Cables/5m+DVI-D+Dual-Link+Digital+Monitor+Cable+?productId=50632
A pin fell of mine today for some odd reason(was cleaning gpu, put gpu back in and a pin was missing) and i saw a 5 meter dvi cable. Would anyone care to explain the point of such a crazy big cable.
Listen if you care.
https://linustechtips.com/topic/56685-5meter-dvi-cables/
For longer distances..... Isn't it obvious?
I cant really think of a reason above 3 meter maybe 4 meters but 5, thats like routing a cable from one house to another and still zip tieing some of it down.
If your computer is 5 meters away from your monitor...
At this rate i could use the cable to route linus's pc to my monitor.
Listen if you care.
https://linustechtips.com/topic/56685-5meter-dvi-cables/#findComment-766033
Its not finished yet
https://linustechtips.com/topic/56685-5meter-dvi-cables/#findComment-766038
Pretty much every application where you're set up quite some distance from the screen xD
when you hook up to a beamer maybe? I have used 30 meter HDMI cables before and other crazy length VGA cables. but that was in a large theater though.
Does anyone even use PCIe SSDs?
https://linustechtips.com/topic/56685-5meter-dvi-cables/#findComment-766052
If you have 3 monitors and your pc is on the ground you will probably need 1.
- teamspeak.ltt-unofficial.com
- teamspeak.ltt-unofficial.net
- teamschnitzel.ltt-unofficial.com
- teamschnitzel.ltt-unofficial.net
cpu: Intel sandybridge-E 3930k @ 4.2Ghz
cooler: corsair h100 @ full speed push-pull
motherboard: Asus Rampage IV Extreme
gpu: 2x EVGA GTX660's & 1x EVGA GTX980
ssd: 2x samsung 256GB 840 pro raid 0
ssd: 1x samsung 1TB 840 evo
hdd: WD green 3TB
hdd: Seagate Barracuda 1TB (st1000dm003)
hdd: Seagate Barracuda 1TB (st31000520as)
psu: corsair ax1200i
ram: 8x 4GB corsair platinum @1866mhz
case: coolermaster cosmos II
age: Do the math (summer 2012)
monitors Main: 8x LG 22EA53 1080p 60hz
monitor Extra: 1xiiyama prolite G2773Hs 1080p 120hz 27"
os: windows 7 pro (64-bit)
keyboard: logitech g19
mouse: corsair m60
Lenovo T550
RaspBerry pi webserver:
Status: Offline.
Nas:
StatusOffline.
PC straight to the modem/router/switch/DHCP-Server/... with a 20cm (+-8inch) cat6a patch cable because same price as cat5.
ISP: Telenet (belgium)
Speed: 60Down-4Up (+- 45€/month)
ping to there servers: +-8ms
ping to other Belgians: +-12ms
- wheels for cosmos II
https://linustechtips.com/topic/56685-5meter-dvi-cables/#findComment-766054
I will probably need a 2, 4or5 meter cables for my monitors when I move my desk.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/56685-5meter-dvi-cables/#findComment-766071
Not nessassarily for home use,
But in a commercial/public environment they can end up using DVI cables >100M in length etc
So yes there is a use, just not what you would normally think of.
Arch Linux on Samsung 840 EVO 120GB: Startup finished in 1.334s (kernel) + 224ms (userspace) = 1.559s | U mad windoze..?
https://linustechtips.com/topic/56685-5meter-dvi-cables/#findComment-767142
I completely understand for a business but not for home usage.
Listen if you care.
https://linustechtips.com/topic/56685-5meter-dvi-cables/#findComment-767211
