6 minutes ago, KSores said:
No time soon but eventually i want to put a custom loop in my nzxt noctis 450. does my case support it?
definitely
i know its a h440, but its the same internal and the n450 actually supports watercooling slightly better
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/566843-nzxt-noctis-450-loop/#findComment-7446721
5 minutes ago, tahmidkhan123 said:
its got rad support but you might have to drill holes for pumps and such. Most cases require custom pump mount holes. A few people have water cooled in this case and it looks doable, although not your best choice.
well the bottom comes with screw holes for hard disks, should be able to get a converter so he doesnt need to be drilling his case to mount it lol
the reservoir can be mounted with the holes on the panels thats hidden by the case's side panel with zipties and what not :D
16 minutes ago, KSores said:
though if you wanna put a radiator in the front, you will need to sacrifice your drive cages, which might be a problem for you :D
https://linustechtips.com/topic/566843-nzxt-noctis-450-loop/#findComment-7446752
i only need 1 3.25 inch bay
could i fit the res there somehow?
and a radiator in the top?
https://linustechtips.com/topic/566843-nzxt-noctis-450-loop/#findComment-7446767
so many variables... but you can probably mount the pump and reservoir combo at the bottom, put 240mm rad in the front taking up the two bottom slot, put your hard drive at the top slot, and put 240/280/360mm radiator on the top (360mm if it doesnt interfere with your hard disk)
https://linustechtips.com/topic/566843-nzxt-noctis-450-loop/#findComment-7446771
