500w is enough.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7443847
1 minute ago, MrIceCremeLollipop said:
This will be the setup:
Gtx 950 - Might oc the smallest bit.
Core 2 quad q6600 - No ov
4 Sticks of ddr2
2  fans
3hdds
Some breathing room for oc, more fans ect.
How big should my psu be?
Thanks :D
I am NOT going to answer your exact question. Instead I would like to give you some advice. When you CAN futureproof something, you should.
A PSU is something you can keep over the course of several upgrade cycles, therefore get something of high quality and decent wattage.
I would recommend at least 500W, and at least 80+ Bronze AND a reputable brand. If you need suggestions, we will gladly provide some.
500W will give you enough wattage for almost any up-to-date, reasonable CPU+GPU combination (unless we are talking dual-GPUs).
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7443863
Wow Thanks :)
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7443874
Just this one.
Wat8.jpg.b11fd5fa380a1aa60d92c11be5ccaa0
Lol, JK. 500W is enough, but if you know that you are planning on upgrading in the future to more powerful hardware and you have the money available now you could just get a bigger one for the future.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7443940
4 Sticks of ddr2
2  fans
3hdds
Thanks :D
550W is more than enough
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7443965
You will be able to SLI on 600W, I've done that with GTX 660s though, I imagine you'd only do it in the future, without the Q6600
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7443982
25 minutes ago, Toxicknight79 said:
btw in case you happen to want to know this again ..........
Power supply calculator site
That page says that my system would use 500w under load( 4790k and 970) and I can't even break 330
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7443983
itll factor in all things plugged into the pc ,, not just the pc  itself ,,, you add in  backlit keyboards  powered DAC  from USB , allot of fans, etc. The wattage estimate is basically saying  youll be safe using this amount. it  wants to be generous  because   you run a power supply at its rated watts that power supply  loses its efficency , plus lifespan ,,,,, I run a pc not breaking 120 watts and I run a 430watt power supply in it lol.
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7445438
And? My power supply registers the power consumption of EVERYTHING connected to the pc, just 330 watts when it says that i should be consuming 500w, those calculators are not reliable at all
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7446977
better to have too much wattage than  too little ,, just sayin.
https://linustechtips.com/topic/566599-how-many-watts-do-i-need/#findComment-7447192
