Hey guys, so basically I can't connect to Snapchat via cellular data anymore. All my other apps work fine, but not Snapchat. It just won't refresh, even on a 4G and 4 bar connection it will not connect. I'm using an Asus Zenfone 2 on AT&T, running Android 5.0.2 and cellular data is enabled for it. If anybody knows any fixes that'd be great
Sally: l Intel i5 4690k | | Corsair H55 | | Zalman z12 plus | | Hitachi 2TB HDD | | Samsung 840 Pro 128 GB | | ASRock Fatal1ty z97 Killer | | Corsair Vengeance 16 GB | | EVGA SuperNova 750 watt | | MSI 390 | | Windows 10|
https://linustechtips.com/topic/566208-snapchat-not-connecting-over-cellular-data/
Have you tried powering off and on your phone?
Have you tried restarting your phone?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
Yes I have
Uninstall the app then download it again and i think it should work.
I'll  do that
19 minutes ago, MattLantis said:
I'll  do that
If you go into the app itself there is an option that disables data over cellular networks and only allows the app to work when connected to a wifi network. Maybe take a look at that ?
I'm gonna check that out
On 3/16/2016 at 6:19 PM, Ronnie76 said:
I wouldn't use it over data if your using it as a messenger
It uses so much data, if its not an issue then go ahead, use it, I would advise against it because it drains a lot of data and a lot of battery.
I don't use data for anything else so it's not too much of a problem, and battery isn't too bad tho
