so im putting together my pc and i have a modular 750w psu and whenever i try to connect my first fan my pc dioesnt boot, but it will for the second fan, they are both 120mm case fansconnected by a daisy chain chord that came with the psu and whever i even put it into the mobo in the sys fan plugs it doesnt post and nothing comes on, as in my cpu fan or mobo LED's
idk what the problem is i should have enough watts
here are my specs:
AMD 8350 cpu
GTX MSI 950
970A-G46 mobo
WD 1 tera HDD
a CD/DVD burner
and a 750 watt psu
https://linustechtips.com/topic/566087-fan-connecting-help/
