yes. The i5 is NOT A BOTTLENECK. You are good :)
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/566080-will-it-run-ultra/#findComment-7437999
6 hours ago, TidaLWaveZ said:
-snip-
Bottleneck is a simple way of saying that One part will hold back another. In this case he thought the processor would be a bottleneck to the graphics card.
https://linustechtips.com/topic/566080-will-it-run-ultra/#findComment-7438048
it'll run fine on your PC, I have it and it's very easy on the hardware.
Intel 5820K OC@4.7 / MSI Raider X99 / 32GB Corsair Dominator 3200mhz / x2 EVGA 980Ti Hybrid OC @1468 / Corsair Vengeance C70 (OD Green) / 2x Samsung 840 Evo in Raid 0 / Corsair RM1000x / Corsair H110i GTX  - Firestrike Score – 26156 (so far, lol)
https://linustechtips.com/topic/566080-will-it-run-ultra/#findComment-7438687
