Networking and Bottlenecks
Go to solution Solved by Samfisher,
1 minute ago, Charlicious said:
Thanks! Gotcha. Bottomline is, in theory, at best, I would able to achieve speeds up to a max of 1Gbps?
And accounting for the SSD bottleneck of 550MB/S, how would that affect my download/upload speeds?
Well, you'd need a 4 Gigabit line to come close to saturating your SSD speeds :P 1 Gigabit = 125MB
That is if the source even lets you download that fast.
Hi everyone,
I've spent days 'studying' and learning whatever I can about networking and possible causes for bottleneck and I just thought maybe I could get opinions from you guys.
The current build:
Asus M5A97 EVO R2.0 Motherboard
Windows 7 SP1 (I just prefer it that way)
8GB Corsair Vengeance RAM 1600Mhz
Sapphire R9 270X Dual X GPU
960GB Sandisk Ultra II SSD
1TB WD Green HDD
VS650 Corsair PSU
ASUS RT-AC88U Router
The situation:
  • I have just signed up for a 2Gbps Fibre Optic Broadband service.
  • I am looking at direct connection from PC to Router via Cat 7 Ethernet Cable
  • I would like to get the most out of the awesomely reviewed Broadband service without hitting a bottleneck (due to software/hardware).
The help I need:
  1. With the facts I have presented, I would like to know what kind of issues I might face.
  2. Which of my hardware will cause a bottleneck in my internet connection.
Thanks a whole bunch fellas!
https://linustechtips.com/topic/566008-networking-and-bottlenecks/
Your NIC.  You'll need to get a 10Gigabit one, and HOPEFULLY your ISP isn't cheating you and giving you a router with only Gigabt ports.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
4 minutes ago, Charlicious said:
Hi everyone,
The current build:
1TB WD Green HDD
VS650 Corsair PSU
The situation:
The help I need:
Hardware won't cause any significant issues with your broadband. I'd be more worried about the ISP delivering their promised performance.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
I'd consider myself really new to these stuff. NIC present on my MOBO will cause the bottleneck?
Edit: I see it now..
Wired network ports 1x 10/100/1000Mbit/s
Yes. VERY few motherboards come with 10 Gigabit NICs, and yours isn't one of them.
