How to best implement drain ports?
Solved by ISOlated,
Yeah I am planning on doing hardline where you can actually see it and soft tubing for all the 'behind the mobo-tray' routing so I will probably just copy Jayztwocents's approach and split the soft tubes with a Y-Connector and put a plug similar to this one: https://www.caseking.de/bitspower-absperrhahn-1-4-zoll-shiny-black-wazu-234.html (Yeah sorry it's German :P)
Featured Topics
realfireguy ·
Posted in Graphics Cards0 -
Winterlight ·
Posted in Phones and Tablets1 -
3
ineedhelp.2145 ·
Posted in General Discussion0 -
1
atxcyclist ·
Posted in Home Theater Equipment1 -
1
2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
