CPU Cooler that Fits
Go to solution Solved by aisle9,
The Cryorig H7 fits that case and is designed not to interfere with RAM at all. I use it on my 4790K, overclocked to 1.205v with peak OCCT temps below 80C. The beQuiet! Pure Rock is also an option, but I can't speak to its RAM clearance.
Hello,
I am looking for assistance on the best air, or AIO water cooler that would fit in this case (IN WIN 805; http://www.inwin-style.com/en/gaming-chassis/805#product_spec) for LGA 1150 socket.  This is the full build if curious: http://pcpartpicker.com/p/GTKBsY and I want to make sure there is RAM clearance. I am also wondering what the best Noctua PPC fan would be for either the AIO or air cooler.  I am open to other brands if they have good performance.
Thank you for any assistance!
https://linustechtips.com/topic/565376-cpu-cooler-that-fits/
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/565376-cpu-cooler-that-fits/#findComment-7430533
